2811 E1
Mar 16th, 2008
I have cisco 2811 with VWIC-2T1/E1-RAN installed. I have IOS
(C2800NM-IPVOICE-M), Version 12.4(18)
But it is not recognizing the E1 card.even card router is not recognizing the card type command.
WIC Slot 0:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware Revision : 3.0
Top Assy. Part Number : 800-25833-03
Board Revision : E0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : FOC11302ZTB
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Version Identifier : V01
Product (FRU) Number : VWIC-2T1/E1-RAN
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 04 BF 41 03 00 C0 46 03 20 00 64 E9 03
Please tell me which IOS will support these commands.
Overall Rating: 5 (2 ratings)
paolo bevilacqua Sun, 03/16/2008 - 16:31
  • Hall of Fame,
    Founding Member
That card is special made for telco and wireless operators, and is supported only in selected images. Please try an image from 12.4(11)SW3.
wasiimcisco Sun, 03/16/2008 - 17:53
Thanks for the reply, I upgrade the IOs 12.4(11)SW3 and now i am able to get the E1 card.
Thanks for the help and support.
