Does the Pix support secondary IP addresses
Answered Question
Mar 16th, 2008
I have aPix FW running version 6.3(3), can the Pix FW support additional/secondary IP addresses on its interfaces much like a router can ?
Thanks inadvance
Stu
Correct Answer by jefanell about 8 years 10 months ago
Only one IP address can be configured on a given interface.
What is the design goal you are trying to achieve? If it is simply to provide a gateway to more than one subnet, why not put them on separate VLAN's?
http://www.cisco.com/en/US/docs/security/pix/pix63/configuration/guide/bafwcfg.html#wp1112226
Overall Rating: 5 (1 ratings)
cisco24x7 Sun, 03/16/2008 - 19:47
believe it or not, there are places that still
use hub instead of switch. They want to
separate layer-3 while having multiple network
with different networks connected to the same
hub. That's what router's secondary address is
designed for, among other things.
jefanell Sun, 03/16/2008 - 19:52
I understand completely. Unfortunately, the ASA/PIX platform is focused on security, and as such does not have all the flexibility of the IOS router platform. The only other option I can suggest is to front-end the ASA/PIX with a router.
stuart.jones Mon, 03/17/2008 - 13:47
Thanks for the reply, i was thinking that it didnt support it, and yes to your question they want to extend the connected subnets, so VLANs might well be the way to go, thanks for the reply
