ACE Redundancy - Two Module
Mar 16th, 2008
i have two ACE Module in different chaisses
i want to make Data-Center1 primary for all contexts and Data-Center2 standby for all contexts
there is no commands Primary unit and standby unit like FWSM
how to acheive that?
Roble Mumin Mon, 03/17/2008 - 01:43
  • Bronze, 100 points or more
You achieve this by associating a priority to each FT group.
Example:
ft group 1
peer 1
priority 150
peer priority 110
associate-context Admin
inservice
ft group 2
peer 1
priority 150
peer priority 110
associate-context Foo-Bar
inservice
That's all you need. For further details have a look at the ACE-Admin Guide.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/administration/guide/redundcy.html#wp999520
Roble
majaj Mon, 03/17/2008 - 07:45
thanks
what about SSL Certificat and SSL Key does they replacated to the second ACE or we need to export and import them to the second ACE
ciscocsoc Mon, 03/17/2008 - 07:56
  • Silver, 250 points or more
You'll need to export and re-import into the contexts on the second ACE. If there is a difference in the files then replication will stop working.
Cathy
Roble Mumin Mon, 03/17/2008 - 08:13
Yup, certificates and keys have to be manually imported on both ACE's.
Roble
