Problem Loading Image on 1700 router
moses12315
My router does no load the image . At the attachments you can see all the output.
What shall i do?
Thanks a lot
moses
guruprasadr
Level 7
Level 7
HI Moses, [Pls Rate if HELPS]
This message only occurs when you load images that run from RAM. Cisco 1700 Series routers support images that run in RAM and images that run directly from Flash (for example, relocatable images), there are two solutions for this problem:
1. Upgrade the DRAM
2. Load a relocatable image; load an image from Flash
Refer LINK Below:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_tech_note09186a008009483a.shtml
Hope I am Informative.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
Hi and thanks. I wrote the command
rommon 8 > boot flash:c1700-advsecurityk9-mz.124-17.bin
but i have the same results.
The flash is this
rommon 7 > dir flash:
File size Checksum File name
13707088 bytes (0xd12750) 0xbd90 c1700-advsecurityk9-mz.124-17.bin
thanks
moses
I don't thinkso your Router is capable of booting on Image c1700-advsecurityk9-mz.124-17.bin
> It doesn't have enough RAM available to load on the new Software
Read the release notes below:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/1700/1700rlsn/index.htm
PLS RATE if HELPS
Best Regards,
Guru Prasad R
