E1 controller question
Mar 17th, 2008
I have four PBXes in four locations.
each pbx has its own E1 trunk port.
Also I have a lan in each location and the connectivituy between locations are also E1.
is this possible to :
1.I assign all the e1 timeslots to pbx
with nm-1cue1-pri module
2)again with nm-1cue1-pri connect to other locatins
Paolo Bevilacqua Mon, 03/17/2008 - 03:01
There is no such product named nm-1cue1-pri.
What router type do you have in all locations ?
emadehsan Mon, 03/17/2008 - 04:27
i have 3845 in each location.
PBX---E1---router-----E1-----router---E1--PBX
Paolo Bevilacqua Mon, 03/17/2008 - 04:39
You need either vwic-2mft-e1 or vwic2-2mft-1e1/t1. These are two-port E1 cards, one port connects to pbx, other to wan circuit.
Also you need the dsp module, called pvdm2-xx where xx is the number of voice channels you need. Available sizes are 8, 16, 32, 48, 64.
Paolo Bevilacqua Mon, 03/17/2008 - 10:34
It can be lengthy, if you never configured voip I suggest you hire someone with experience as it can be frustrating the very first time.
Write back onece you've the hardware in palce.
