changing WCS web ports....
Mar 17th, 2008
is there a way to change the WCS web ports (http, https) on the WCS that is already up and running?
Overall Rating: 5 (2 ratings)
ericgarnel Mon, 03/17/2008 - 07:09
In the linux version
edit httpd.conf under /opt/WCS/webnms/apache/conf
and change the ports there
restart WCS
pirateoftheairwaves Tue, 03/18/2008 - 03:15
thanks, eric!
the wcs is running on the windows 2003 server.
anyways, my problem was solved when we asked the customer to open the https port on their firewall.
the problem was, wcs is inaccessible from other subnets, except its own, in the entire lan and wlan. and opening the ports resolved the issue.
thanks for your input.
ericgarnel Tue, 03/18/2008 - 06:33
The file should be the same in windows, but in a different location.
We lock our WCS down to our own management networks as well
Trending Topics - Security & Network
