Periodical change of WPA pre-shared key
Mar 17th, 2008
Hello all,
i need to periodicaly change wpa pre-shared key on my Aironet1232.
Please do you know way how this should be done?
I think that it could be done by SNMP, but I couldn't find the right OID for WPA keys.
Thanks a lot for any idea
Tomas
gmarogi Fri, 03/21/2008 - 07:19
You do not have the configuration option of doing so in the AP. I am not sure whether this is possible through SNMP as well.
The nature of the WPA Pe-shared key is fixed or static.
Trending Topics - Security & Network
