radius local-server authentication problem
Mar 17th, 2008
Dear Sir
I have planed to authenticate our user who connect to our access point via local radius local-server which is located on our access point my access point model is Aironet 1300 and my configuration is as follows but when users from their pc enter password their authentication will fail. Would you please let me know what is wrong in my configuration?
version 12.3
no service pad
service password-encryption
hostname ap
enable secret xxx
ip subnet-zero
aaa new-model
aaa group server radius rad_eap
server 10.10.10.1 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa group server radius rad_acct1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa accounting network acct_methods1 start-stop group rad_acct1
aaa session-id common
dot11 ssid cisco
authentication open eap eap_methods1
authentication network-eap eap_methods1
accounting acct_methods1
guest-mode
infrastructure-ssid
wpa-psk ascii xxx
power inline negotiation prestandard source
username Cisco password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit xxx transmit-key
encryption mode wep mandatory
ssid cisco
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
antenna receive left
antenna transmit left
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid cisco
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 10.10.10.1 255.255.255.128
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
no authentication eapfast
no authentication mac
nas 10.10.10.1 key xxx
user test nthash 7 xx
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.10.10.1 auth-port 1812 acct-port 1813 key xxx
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
line vty 0 4
end
Best regards
hyazdi
Trending Topics - Security & Network
