CCM Backup problem
Mar 17th, 2008
Dear Networkers,
I am facing a problem when I try to backup our CCM, software version is, it seems that the Host key verification.
I upgrade the CCM, and the problem still occurs.
on the other hand , we have another cluster and I can take the backup. Therefore ,there is no problem with the SFTP server.
Please find attached log file.
Kindly your advice
spotlight41 Mon, 03/17/2008 - 06:57
what do you mean by, "I upgrade the CCM"? 6.0? I had the same backup issues with 5.1.2. TAC has to dial in and fix it remotely. It worked perfect after this 10 minute fix.
