Danilo Dy Mon, 03/17/2008 - 05:30
Can you post the network topology showing end-to-end link between two sites (both primary and secondary link), including type of lines?
...you may add the router configuration.
Dandy
Goutam Sanyal Mon, 03/17/2008 - 05:49
Hi Mirza, When your primary link i.e. LL, MPLS etc. etc. goes down and you are able to connect the remote side via next link which is note as secondary i.e. ISDN, DSL, 56Kbps Modem etc. known as fail over. It's with in a single sentence. Thanks Goutam.
