Pix515 memory question
Mar 17th, 2008
  • Silver, 250 points or more
Is it unusual to see a Pix515 with 256MB
of RAM? Is it even possible? See below:
iscoPix> sh ver
Cisco PIX Security Appliance Software Version 7.0(7)
Compiled on Fri 06-Jul-07 10:37 by builders
System image file is "flash:/pix707.bin"
Config file at boot was "startup-config"
CiscoPix up 13 hours 51 mins
Hardware: PIX-515, 256 MB RAM, CPU Pentium 200 MHz
Flash i28A98150 @ 0x300, 16MB
BIOS Flash AT21f57 @ 0xfffd8000, 32KB
0: Ext: Ethernet0 : address is 0004.2975.245e, irq 11
1: Ext: Ethernet1 : address is 0004.7297.124f, irq 10
Licensed features for this platform:
Maximum Physical Interfaces : 3
Maximum VLANs : 10
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has a Restricted (R) license.
Serial Number: xxxxx
Running Activation Key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Configuration last modified by enable_15 at 13:59:43.931 UTC Sun Mar 16 2008
CiscoPix>
abinjola Mon, 03/17/2008 - 04:38
  • Cisco Employee,
hello 24/7
This is not unusual at all
Pix 515/515E has two dimmer slots , each slot can fit in 1 memory stick , in your case you must be having 2 - 128MB sticks into each slot
hope it helps !
cisco24x7 Mon, 03/17/2008 - 04:48
Hi abinjola,
The follow-up question is "does this configuration support by Cico"?
Most of the time, Pix515 usually has either
64MB or 128MB.
Thanks.
abinjola Mon, 03/17/2008 - 05:00
  • Cisco Employee,
hey 24/7..yes you are very correct..this is not recommended to have 256 MB, though it might run fine
The standard memory configuration for the PIX 515 is a 32 MB DIMM memory strip installed into one of two slots. If you are upgrading a 32 MB system, add a second 32 MB DIMM memory strip into the empty slot.
hope this helps !
