Standalone installation Unity VM version 5
Mar 17th, 2008
Hello
I have a MCS-7835-H2 and UnityV5 software.
I have no connection with the office network and there fore I will install the server and SW as standalone , so that all the applications like outlook etc etc are running on this server.
On the Cisco sit a see a lot of documents, but not any one for the standalone installation.
Has anybody an idea ?
Tommer Catlin Mon, 03/17/2008 - 08:35
Basically you need the following:
- Unity 5, AD domain, Exchange 2003, SQL all on one box.
OR
- Unity 5, AD Domain, SQL on one box, and Exchange 2007 OFFbox.
Stand alone, you still need to build a "small" AD domain, DNS, etc to make it run.
Ginger Dillon Mon, 03/17/2008 - 16:32
Hi and hope you don't mind my two cents -
You cannot install Outlook on the Unity server, even if you are running a stand-alone server with AD, Exchange, and Unity onbox. Outlook will impact the MAPI connection between Unity and Exchange. If you need Outlook, install it on a workstation that is connected to the same domain as the Unity server.
Regards, Ginger
Tray Stoutmeyer Mon, 03/17/2008 - 20:07
Ginger is very correct but I assumed that by Outlook you really meant Exchange but again, it's a good clarification on her part.
Tray
ranpierce Tue, 03/18/2008 - 10:08
No she was right. You cannot install outlook on the Unity box.
The reason is that the MAPI.dll in outlook is different than the MAPI.dll in exchange. Unity needs the Exhange version.
rlp
Tray Stoutmeyer Tue, 03/18/2008 - 13:53
That is what I was saying ranpierce. It's the same reason why any time you update Exchange and it's off box, you have to update the tools on Unity to make the mapi dll the same. Not sure where you got that I thought ginger was wrong. Sorry if there was some sort of mis-communication here.
Tray
