sla command and track objects v12.4(15)
Mar 17th, 2008
Hi all,
I have upgraded my cisco router 857 to version 12.4(15)T3.
And when I try to use the track command it doesn't recognise it:
C857(config)#track 1 rtr 1 reachability
% Invalid input detected at '^' marker.
C857(config)#
C857(config)#track ?
% Unrecognized command
C857(config)#track
I have created a sla object:
ip sla 1
icmp-echo X.X.X.X source-interface Dialer0
timeout 3000
threshold 3
frequency 3
ip sla schedule 1 life forever start-time now
And now I would like to use it to check the default route:
C857(config)#ip route 0.0.0.0 0.0.0.0 dialer 0 track ?
<1-500> tracked object number
C857(config)#ip route 0.0.0.0 0.0.0.0 dialer 0 track 1
I can use track objects but I can't create them. :-(
The problem is that I don't know how to associate sla 1 with track 1 in this new version since the router doens't recognise track command.
Could anyone help me?
Thanks and Regards, Fernando.
Overall Rating: 3 (1 ratings)
networkingib Tue, 03/18/2008 - 03:05
Wow! Really? :-/
What I don't understand is why I can use track objects but I can't create them.
Well, I would have to look for a diferent way to do what I want.
Anyway, Thanks.
Regards, Fernando.
Joe Clarke Tue, 03/18/2008 - 08:48
You can use the Feature Navigator to see which features are supported in different IOS versions and platforms (http://www.cisco.com/go/fn/ ). The smallest platform to support tracking is the 1700 series.
