2 connection to the same ISP
Hello guys,
Can you help with the following problem:
I have 1800 series router. I already have one E1 on the router which is 2Mb.
We want to install second with different speed to the same ISP(most probably NOT to the same device on the IPS/s site). How to do loadbalansing not only failover. If I insert 2 routes pointing to the respective default gates the router uses the first one and the second is just failover link.
Any help will be apriciated!
James Lasky Mon, 03/17/2008 - 07:41
Do you mean loadbalancing of traffic incoming and outcoming ?
You can force only outcoming...
Did you enabled CEF loadbalancing per packet ?
Do you get backword traffic balanced? This is a job of your ISP...
