Call Intrusion.
Mar 17th, 2008
Need an advice. Task is to provide a call intrusion function. Barge function isn't appropriate, because we need that every user call to be released if a management call has come. Such a function provided by Alcatel PBXs as an option. Any suggestion will be appreciated.
Jaime Valencia Sat, 03/29/2008 - 20:15
  • Cisco Employee,
  • Hall of Fame,
    2011
use UCCX or UCCE in which you can set a supervisor and enable the monitoring feature to achieve this
javalenc
if this helps, please rate
Ruslan Kravets Fri, 10/07/2011 - 00:09
Hi!
Is there an ability to implement this function just of CUCM facilities only?
Ruslan
Jaime Valencia Fri, 10/07/2011 - 06:16
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM only provides barge, if that works for you, then you can use it.
If you want to monitor non-shared lines from your phone then UCCX/UCCX/3rd party is required.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Craig Dyer Tue, 10/11/2011 - 01:13
  • Silver, 250 points or more
     I think the feature you may be looking for is MLPP, it can play a tone into an existing call to tell the people in conversation there is a more important call to be handeled.
     MLPP is based on a military concept to allow priority users to gain access to limited resources.
     The only method of automatically overriding an existing call is MLPP, which is available in both CuCM and CME.
It is documented here:-
CuCM 6.1
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmcfg/b02mlppd.html
CME (for others)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemlpp.html#wp1342853
If  this is for one or two users it is probably more user friendly to put a  second line appearance on the users phone set to allows ring. Then give  the 'boss' special priority numbers to ring. You could even put these  numbers in partitions that normal users can not ring.
Craig
If this helps please rate the posting.
