Network issue
Answered Question
I have Site to Site VPN set up, I can ping and access files across the VPN tunnel.
However the issue is that, it doesn't display the computers on the workgroup on my network neighbourhood( ie remote computers can not see the main office computers)
Is there a way I will be able to see these computers? if so what command can I use to allow me see these computers.
Correct Answer by johnd2310 about 9 years 1 week ago
hi
You will have to enable wins on both sides of the tunnel. If you have wins servers on both sites, then set them as replication partners. If you only have a wins server in the main office, then set remote clients to use that for wins.
regards
John
Overall Rating: 5 (1 ratings)
Correct Answer
johnd2310 Mon, 03/17/2008 - 10:38
  • Silver, 250 points or more
hi
regards
John
Hello John
Does it mean that, it got nothing to do with the vpn setup on these two cisco routers (VPN gateways )?
The customer does not have any wins server. they only use file sharing.
The VPN tunnel is up and the two networks can ping each other and remote sites can access files at the main office.
What I would like to know is whether this customer's request has got nothing to do with the VPN configuration.
I will be very grateful if somebody can reply to me as quickly as possible.
Kind regards
Tarek
