Cisco 800 series - PPPoE client on the LAN interface?
Answered Question
Mar 17th, 2008
Can someone please clarify me if there is any possibility to configure a Cisco 876 or 877 to act as PPPoE client for an external ADSL modem connected to the LAN interface?
In theory it should be possible and I can make the configuration, but in practice it doesnt work properly, and when looking at debugging I think it is not working because of source mac address issues when it sends the PPPoE PADI packet, then the responding PPPoE server sends a PADO response to an invalid/unknown mac address.
Thanks for any help.
Rui
Correct Answer by Paolo Bevilacqua about 8 years 11 months ago
Do you have advanced Ip services software loaded and the vlans set ? Can you sent mac-address under vlan interface ?
Overall Rating: 5 (3 ratings)
Paolo Bevilacqua Mon, 03/17/2008 - 10:35
It is possible and used by many people, what is the issue exactly? You can "clone" the mac address if you want.
RF_IESFAFE Mon, 03/17/2008 - 10:50
If it would be on a model with a WAN ethernet interface like the 871 then it works perfectly.
The problem is the 876 and 877 models have just the ADSL port as WAN, so I have to connect the external modem to a LAN interface.
The 876/877 have four bridged FastEthernet interfaces with 'dumb' mac addresses, and as I cant configure the pppoe-client on other than these FastEthernet interfaces, there is a mac address issue.
I have tried to clone the mac address of one of those ports to the one of the corresponding Vlan interface, but still no success.
The pppoe-client uses the mac of the outgoing interface, but then when a response is received to that same mac address, the 876/877 simply forwards the packet to somewhere else as it does not recognise that 'dumb' mac as of itself.
Rui
Correct Answer
Paolo Bevilacqua Mon, 03/17/2008 - 11:13
RF_IESFAFE Mon, 03/17/2008 - 12:49
Yes it is using an advanced ip services ios image 12.4(15)T3, just recently upgraded from T2.
It does not let me change the mac address of the vlan interface, I have tried that already too, I can only change the mac address of the FastEthernet port to be the same as the vlan but it still didnt work, it did not forwarded the response packet already as it was recognising already the mac of the vlan interface, but it still seems the pppoe-client was not "catching" the response packets... (paused for testing again)
** Update **
I dont know if it was my mistake before or it is because of the new ios version, but now I can configure the pppoe-client on the vlan interface and it is working already as expected.
Your question made me test again this time with pppoe-client in the vlan interface, I did it before with the T2 image but it didnt work, not sure if it was my mistake that time.
Anyway you made me test it again so I own you credits for that.
And I appreciate your time and help with this issue.
Thank You.
Rui
RF_IESFAFE Mon, 03/17/2008 - 13:07
Thank you sir, you deserve the rating as you have also demonstrated good knowledge about this subject and made the correct question that have conducted me to correct my configuration.
Rui
Paolo Bevilacqua Mon, 03/17/2008 - 13:27
Thank you for the appreciation.
Now if you were thinking of adding in the future, another pppoe-client under a different port/vlan, I have to tell you that won't work.
Due to IOS internal architecture there is a limit of one pppoe-client per switched group of ports.
RF_IESFAFE Mon, 03/17/2008 - 13:46
I was not planning to add another pppoe-client to the LAN port for now, but who knows in the future, and that is a very helpfull information that can have saved me a lot of fustration, so thank you one more time.
Currently I am using that pppoe-client on the vlan interface that I've just configured, at the same time with the pppoe-client on the ATM interface.
I have been getting really fustrated for a couple months trying to configure the Cisco to handle two ADSL lines at same time, its very nice to see it finaly working!
Rui
Paolo Bevilacqua Mon, 03/17/2008 - 15:37
I guess you will want now ISP load balancing and redundancy for a failed link.
This requires careful configuration of ip sla (track command), policy routing to send probes out the desired link, and I understand also the "oer" keyword in nat is required to make that translations expire quickly.
If you want to endeavor in that and can't get it right, ask again if and when you're stuck.
RF_IESFAFE Tue, 03/18/2008 - 11:44
I will not need balancing or redundancy, because the two ADSL lines are for two different purposes and profiles, but I will also take note of what you just referenced as it still may be usefull for me in the future, its not easy for me to find so real-life and practical information like that :)
Thank you so much for your kindness.
Rui
vasko.stojanovski Tue, 05/27/2008 - 23:34
Hi all,
I am trying to set up an 877 with a LAN port configured to connect to a second ADSL connection via a pppoe-client configuration on the Vlan1 interface. I would like to load balance (or load-share per-packet) between the two ADSL connections. Inbound traffic is load balanced correctly, however the problem is outbound traffic from the LAN prefers one of the two available Dialer interfaces instead of being load-shared equally. Using IOS 12.4(4)T8.
Here are the relevant parts of the configuration:
Thanks in advance for any help,
Vasko.
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5snap
protocol ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface Vlan1
ip address xx.xx.xx.xx 255.255.255.248
pppoe enable group global
pppoe-client dial-pool-number 2
interface Dialer1
ip address negotiated
ip load-sharing per-packet
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname user1
ppp chap password 0 user1
interface Dialer2
encapsulation ppp
dialer pool 2
dialer-group 1
ppp chap hostname user2
ppp chap password 0 user2
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
Paolo Bevilacqua Wed, 05/28/2008 - 13:12
Hi, after a nat translation is established via a given interface, router will keep using it, as that guarantees that server sees client coming always from a single IP.
To see the load balancing in effect you must have multiple PC's opening sessions to different servers, over time.
Michael Antonakis Tue, 09/21/2010 - 04:27
I've managed to do the same on a cisco 876 router. The router is connected to a single provider via 2 aDSL lines. One line is connected to the atm0 interface and the other to a baudtec router which I have configured to work in bridge mode. I then connected the baudtec router to a fastethernet interface of the c876. I configured pppoe client on the vlan1 interface and monitor both lines by tracking the line status of the dialer interfaces (I could track the reachability via sla icmp-echo requests to the ip addresses of the BRASs or IP DSLAMs but since I connect to a single ISP the ip address is the same). I use policy based routing to load share all traffic except the vpns. Until now everything works perfectly. I use the advance enterprise 12.4(24)T3 ios image.
Just for everyone's reference, here is my configuration:
version 12.4
service password-encryption
hostname ****
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password ****
aaa new-model
aaa authentication login vpncllogin local
aaa authorization network vpnclautho local
aaa session-id common
crypto pki trustpoint TP-self-signed-****
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-****
revocation-check none
rsakeypair TP-self-signed-****
crypto pki certificate chain TP-self-signed-****
certificate self-signed 01
        quit
dot11 syslog
ip source-route
ip cef
ip name-server 195.170.0.1
ip name-server 195.170.2.2
no ipv6 cef
isdn switch-type basic-net3
username **** password ****
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp policy 20
hash md5
group 2
crypto isakmp client configuration group ****
key ****
dns 195.170.0.2 195.170.2.2
pool vpnclientspool
acl ACLVPN
save-password
include-local-lan
crypto isakmp profile vpnclientprf
   match identity group ****
   client authentication list vpncllogin
   isakmp authorization list vpnclautho
   client configuration address respond
crypto ipsec transform-set ENCRYPTION esp-des esp-md5-hmac
crypto dynamic-map DynMap 20
set transform-set ENCRYPTION
set isakmp-profile vpnclientprf
reverse-route
crypto map VPN 1 ipsec-isakmp dynamic DynMap
archive
log config
  hidekeys
track 1 interface Dialer0 line-protocol
track 2 interface Dialer1 line-protocol
bba-group pppoe 2ndWAN
interface Null0
no ip unreachables
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation ppp
isdn tei-negotiation preserve
isdn point-to-point-setup
interface ATM0
bandwidth 732
backup delay 3 3
backup interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
atm vc-per-vp 64
pvc 8/35
  encapsulation aal5mux ppp dialer
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description *** INSIDE ***
ip access-group LAN_Inbound in
ip nat inside
ip virtual-reassembly
ip policy route-map PBR
pppoe enable group 2ndWAN
interface Dialer0
description *** OUTSIDE ***
ip access-group WAN_Inbound in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer idle-timeout 270
dialer string ****
dialer-group 1
keepalive 5 2
ppp chap hostname ****
ppp chap password ****
ppp pap sent-username **** password ****
crypto map VPN
interface Dialer1
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 1
keepalive 5 2
ip local pool vpnclientspool 192.168.2.1 192.168.2.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip route 192.168.2.0 255.255.255.0 Dialer0 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 track 2
no ip http server
ip http access-class 23
ip http secure-server
ip http secure-port ****
ip dns server
ip nat inside source static tcp 192.168.1.10 25 interface Dialer0 25
ip nat inside source static tcp 192.168.1.10 443 interface Dialer0 443
ip nat inside source static tcp 192.168.1.10 465 interface Dialer0 465
ip nat inside source static tcp 192.168.1.10 563 interface Dialer0 563
ip nat inside source static tcp 192.168.1.10 636 interface Dialer0 636
ip nat inside source static tcp 192.168.1.10 993 interface Dialer0 993
ip nat inside source static tcp 192.168.1.10 995 interface Dialer0 995
ip nat inside source route-map Dialer0PAT interface Dialer0 overload
ip nat inside source route-map Dialer1PAT interface Dialer1 overload
ip access-list extended ACLVPN
remark --- VPN IPSec traffic to permit to VPN clients
permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
deny   ip any any
remark ---------------------------------------------------------------
ip access-list extended LAN_Inbound
deny   ip 127.0.0.0 0.255.255.255 any
deny   ip 192.0.2.0 0.0.0.255 any
deny   ip 224.0.0.0 31.255.255.255 any
deny   ip host 255.255.255.255 any
deny   ip host 0.0.0.0 any
deny   tcp any any range 137 139
deny   udp any any range netbios-ns netbios-ss
permit icmp 192.168.1.0 0.0.0.255 any
deny   icmp any any
permit ip 192.168.1.0 0.0.0.255 any
deny   ip any any
ip access-list extended PAT
remark --- NAT overload
deny   ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
deny   ip any any
ip access-list extended Servers_to_Internet
permit ip host 192.168.1.2 any
permit ip host 192.168.1.4 any
permit ip host 192.168.1.10 any
deny   ip any any
ip access-list extended Users_to_Internet
deny   ip host 192.168.1.2 any
deny   ip host 192.168.1.4 any
deny   ip host 192.168.1.10 any
deny   ip any any
ip access-list extended WAN_Inbound
remark --- Phase 1 . Add anti-spoofing entries.
remark --- Deny special-use address sources.
remark --- See RFC 3330 for additional special-use addresses.
remark --- Filter RFC 1918 space.
deny   ip 10.0.0.0 0.255.255.255 any
deny   ip 172.16.0.0 0.15.255.255 any
deny   ip 192.168.0.0 0.0.255.255 any
remark --- Deny your space as source (as noted in RFC 2827).
deny   ip 192.168.1.0 0.0.0.255 any
remark --- Phase 2 . Explicitly permit return traffic.
remark --- Allow specific ICMP types.
permit icmp any any echo-reply
permit icmp any any unreachable
permit icmp any any time-exceeded
deny   icmp any any
remark --- These are outgoing DNS queries.
permit udp any eq domain host dialer_0_ip_address gt 1023
permit udp any eq domain host dialer_1_ip_address gt 1023
remark --- Permit older DNS queries and replies to primary DNS server.
permit udp any eq domain host dialer_0_ip_address eq domain
permit udp any eq domain host dialer_1_ip_address eq domain
remark --- Permit legitimate business traffic.
permit tcp any host dialer_0_ip_address established
permit udp any range 1 1023 host dialer_0_ip_address gt 1023
permit tcp any host dialer_1_ip_address established
permit udp any range 1 1023 host dialer_1_ip_address gt 1023
remark --- Explicitly permit externally sourced traffic.
remark --- These are incoming DNS queries.
permit udp any gt 1023 host dialer_0_ip_address eq domain
remark --- These are zone transfer DNS queries to primary DNS server.
permit tcp host 195.170.0.1 gt 1023 host dialer_0_ip_address eq domain
permit tcp host 195.170.2.2 gt 1023 host dialer_0_ip_address eq domain
remark --- Permit older DNS zone transfers.
permit tcp host 195.170.0.1 eq domain host dialer_0_ip_address eq domain
permit tcp host 195.170.2.2 eq domain host dialer_0_ip_address eq domain
remark --- Deny all other DNS traffic.
deny   udp any any eq domain
deny   tcp any any eq domain
remark --- Allow IPSec VPN traffic.
permit udp any host dialer_0_ip_address eq isakmp
permit udp any host dialer_0_ip_address eq non500-isakmp
permit esp any host dialer_0_ip_address
permit ahp any host dialer_0_ip_address
remark --- These are Internet-sourced connections to
remark --- publicly accessible servers.
permit tcp any host dialer_0_ip_address eq smtp
permit tcp any host dialer_0_ip_address eq 443
permit tcp any host dialer_0_ip_address eq 465
permit tcp any host dialer_0_ip_address eq 563
permit tcp any host dialer_0_ip_address eq 636
permit tcp any host dialer_0_ip_address eq 993
permit tcp any host dialer_0_ip_address eq 995
remark --- Explicitly deny all other traffic.
deny   ip any any
access-list 23 remark >>> HTTP and LINE VTY Access-class list <<<
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 23 permit 192.168.2.0 0.0.0.255
access-list 23 deny   any
access-list 23 remark ----------
dialer-list 1 protocol ip permit
no cdp run
route-map PBR permit 10
match ip address Servers_to_Internet
set ip next-hop verify-availability 80.106.108.152 10 track 1
set ip next-hop verify-availability 80.106.108.152 20 track 2
route-map PBR permit 20
match ip address Users_to_Internet
set ip next-hop verify-availability 80.106.108.152 10 track 2
set ip next-hop verify-availability 80.106.108.152 20 track 1
route-map Dialer0PAT permit 10
match ip address PAT
match interface Dialer0
route-map Dialer1PAT permit 10
match interface Dialer1
control-plane
line con 0
exec-timeout 120 0
login authentication vpncllogin
no modem enable
stopbits 1
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 120 0
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
And here is my routing table
sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
     80.0.0.0/32 is subnetted, 1 subnets
C       80.106.108.152 is directly connected, Dialer1
                       is directly connected, Dialer0
     83.0.0.0/32 is subnetted, 1 subnets
C       dialer_1_ip_address is directly connected, Dialer1
     79.0.0.0/32 is subnetted, 1 subnets
C       dialer_0_ip_address is directly connected, Dialer0
C    192.168.1.0/24 is directly connected, Vlan1
S    192.168.2.0/24 is directly connected, Dialer0
S*   0.0.0.0/0 is directly connected, Dialer1
I have noted in bold the ip address I use as next-hop for the PBR route-map.
Yours Sincerely,
Michael Antonakis
