MARS - Debuging
lm20ele
I have been trying to setup MARS and it seems like is partially working. One of the things I would like to see is the Path Mitigation option. For some reasing I'm getting a "Unable to compute path!"
When I check the logs this is what I'm able to see:
Thread 2051:CLI Script exited with error. Exit code: 1. Error Output: spawn ssh -c 3des -l administrator 192.168.xxx.xx
Thread 2051:Error in CLI access to device 192.168.xxx.xx (ID:142782) for reading System CPU/MEMORY/CONNSThread 2051:Error in CLI access to device 192.168.xxx.xx (ID:142782) for reading System CPU/MEMORY/CONNSThread 2051:Error in CLI access to device 192.168.xxx.xx (ID:142782) for reading System CPU/MEMORY/CONNS
and finally
buildL2Routing: S:<19280738>, Can't compute L2 path, when L3 path was not successfull
Does any body have seen this?
Does any body have
Not applicable
I found the same error message. And later recognized that MARS doent suppiort MPLS or networks where VRF is in picture.
