VPN works with address pool, but not with dhcp server
Mar 17th, 2008
I have remote access vpn working when I use the provided address pool, but if I change the config to point to our dhcp server I get the desired IP information, but can no longer ping anything or access anything internally. config attached thanks in advance
ggilbert Mon, 03/17/2008 - 12:03
  • Cisco Employee,
What is the IP address that is getting assigned to the remote access vpn client from the DHCP server?
Can you tell me the DHCP scope that is configured on the DHCP server.
Gilbert
gmtimmons Mon, 03/17/2008 - 12:19
scope is 10.2.20.x to 30.x mask of 255.255.192.0 it gets a proper ip from dhcp such as 10.2.21.x with mask and dns servers, but no access after that
thanks
ggilbert Mon, 03/17/2008 - 13:08
  • Cisco Employee,
In your logs on the ASA do you see any port translation error message for the IP address assigned to the client when you try to access the internal network?
Gilbert
