2811 IOS Problem
Mar 17th, 2008
I have cisco 2811 router with VWIC-2T1/E1.
I want to configure it as voice gateway but the problem is that it is not recognizing the E1 card. If i change the IOs it recognize the E1 card but later on it is not supporting the Voice commands.
I have changed so many IOS but if one IOS recognize E1 card the same IOS not support voice command, and vice versa, please tell me which IOS support both vocie and E1 card.
Below mention is IOS that i have tried
c2800nm-itpk9-mz.124-11.SW3
c2800nm-advipservicesk9-mz.124-3h
c2800nm-ipss7-mz.124-11.SW3
c2800nm-ipvoice-mz.124-18
c2800nm-adventerprisek9_ivs-mz.124-2.T6
paolo bevilacqua Mon, 03/17/2008 - 13:04
  • Hall of Fame,
    Founding Member
I'm afraid that due to the fact the card you using (viw-2t1/e1-ran) is not a regular vwic but a special version made for SS7, there is no image that has both support for that card and voice support.
wasiimcisco Wed, 03/19/2008 - 03:04
HI
i need your help regarding the module for 3825 and 7206 VXR router.
I wanted to have more ethernet port for 3825.Kindly tell me
Cisco 3825-AC-IP : HWIC-4ESW 4-port 10/100 Ethernet switch interface card
Will that fit better for my 3825 router. Router has two slots. Will i required NM or HWIC will directly fit intot the slots.
secondly i need E1 module for 7206 VXR router.
Cisco 7206VXR (NPE-G2) is model. I will terminate E1 connection into new ports. Kindly tell me will
PA-MCX-4TE1 Four-port MIX multichannel T1/E1 port adapter with CSU/DSU
better for it. I need to transfer only data, please do let me.
I want to avoid any problem that i m facing currently with wrong module of 2811.
I will be very greatful to you, if you will help me out.
