GSS CNR installation
Mar 17th, 2008
Hi!
I have a GSS 4492R appliance and I have a CNR to install on it.
The GSS is up and running.
I have followed the installation manual for the CNR: I got the license and installed it. However I am having trouble in the next step which is to execute the following command:
cnr install cnr_6_3-linux.gtar.gz cnr-license xxxx-xxxx-xxxx-xxxx
I don't know where the cnr_6_3-linux.gtar.gz can be found. I have tried all the plausible files that I could find in the CD that came with the CNR.
Can you guys help me?
ebreniz Fri, 03/21/2008 - 13:00
  • Silver, 250 points or more
That's normal - the basic GSS does not need a license, only the DDOS and CNR components need to be licensed.
It depends on if you want to use the DDoS or CNR features on the GSS. If you want to use the GSS as a global server laod balancer then you do not need these new licenses.
However, if you want to use the DDoS or CNR feature then you must purchase and apply the licenses.
