Call Redirect - Busy doesnt work
Mar 17th, 2008
Hi there,
I'm trying to use the call redirect step.. if the destination is busy, it should do a Call_on_hold, play a prompt then do a Call_unhold ...
But the script does not enter in the Busy... it just go to the next step of the script..
any help ?
andrei.goncalves Mon, 03/17/2008 - 13:16
Hi there !
the busy trigger os the phone is already set to 1....
Thanks.
Andrei.
