Simple traffic shaping on border router
Mar 17th, 2008
I've got two 3845's, each with a DS-3, carrying two subnets on them for my border routers. Some simple traffic shaping was set on the two Gig interfaces to allow for bandwidth limiting. I.E.- i wanted to be able to put a cap on the amount of BW each port would use. Unfortunately, the policy is not actively working. A # of times recently, one interface has used up the entire DS-3.
Below are the pertinent command lines:
interface GigabitEthernet0/0
description ***Corporate Traffic***
ip address X.X.X.1
duplex full
speed 100
media-type rj45
traffic-shape group 151 15480000 15480000 15480000 1000
interface GigabitEthernet0/1
description ***Connection to ECOM***
ip address N.N.N.1
duplex full
speed 100
media-type rj45
traffic-shape group 161 30600000 30600000 30600000 1000
interface Serial1/0
description ***ISP CIRCUIT - DS-3***
ip address ....
dsu bandwidth 44210
traffic-shape group 150 15480000 15480000 15480000 1000
traffic-shape group 160 30600000 30600000 30600000 1000
access-list 150 remark *** Rate Limit Corporate Inbound ***
access-list 150 permit ip any X.X.X.0 0.0.0.255
access-list 151 remark *** Rate Limit Corporate Outbound ***
access-list 151 permit ip X.X.X.0 0.0.0.255 any
access-list 160 remark *** Rate Limit ECOMM Inbound ***
access-list 160 permit ip any N.N.N.0 0.0.0.255
access-list 161 remark *** Rate Limit ECOMM Oubound ***
access-list 161 permit ip N.N.N.0 0.0.0.255 any
Any advice?
Thanks in advance!
paolo bevilacqua Mon, 03/17/2008 - 17:01
  • Hall of Fame,
    Founding Member
it seems to me your acl are swapped around. try:
int s1/0
traffic-shape group 151 ..
And remove traffic-shape under lan interface, these don't make much sense as the traffic has reached the router already.
Joseph W. Doherty Mon, 03/17/2008 - 18:10
Trying to throttle inbound bandwidth on the receiving router is very difficult. (Especially using shapers; policers would work a bit better, but you'll still see inbound bursting on the WAN link.)
PS:
For (WAN) outbound, you might want to consider allowing traffic to not be limited by the shaper if the other group isn't using its bandwidth (although maintain the 1:2 [15:30 Mbps] ratio when both want more). This can be accomplished using CBWFQ.
