VPN Tunnel 506 vs 515e
Mar 17th, 2008
I upgraded from a PIX506 to a PIX515e w/vac+ and all of my software based VPN connections work execpt for the two site-to-site tunnels I had. We rechecked the pre-shared keys. How can I determine why these tunnels won't work on the 515e? They were fine on the 506. We even have the 515e at the same IOS level the 506 was. Thanks for any and all assistance.
JORGE RODRIGUEZ Mon, 03/17/2008 - 17:07
  • Green, 3000 points or more
First check show version on new PIX 515E, and make sure VPN-3DES-AES: is Enabled.If 3DES/AES is ok then you will need to debug it to find out where the tunnel fails.
Jorge
vitalcom1 Mon, 03/17/2008 - 17:18
It's enabled
What commands do I use to debug a tunnel?
JORGE RODRIGUEZ Mon, 03/17/2008 - 17:40
Dwayne, please double check l2l configuration again between both firewalls , all parameters must match. Debuging is your last resort! and as you know should be use in non production hours. go over again on some config checks
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml#intro
for debugging
pix#config t
pix(config)#loggin buffer debugging
pix#debug crypto isakmp
pix#debug crypto ipsec
try to bring up the tunnel by sending interesting traffic
pix#show debug
copy debugg output and post it
edit: when done with capturing debug output disable debugging process.
pix#no debug crypto isakmp
pix#no debug crypto ipsec
vitalcom1 Mon, 03/17/2008 - 18:09
I get
debug crypto disakmp 1
debug crypto ipsec 1
Not exactly what I was expecting.
JORGE RODRIGUEZ Mon, 03/17/2008 - 19:36
Sorry..
pix(config)#terminal monitor
bring up tunnel by sending a ping to destination host.. you should see output of tunnel negotiation .. please try. and post output..
