manipulating vlan traffic to a single switch
Mar 17th, 2008
hi
question on switching
im trying to make traffic for a cerain vlan say vlan 44 go through port number 15 on my dl switch. if that port fails i want the traffic to go through port 14 and if that fails through port 13
any ideas?
Collin Clark Tue, 03/18/2008 - 06:31
IMO the best way to do that is with Spanning Tree. You will have to manipulate a metric to determine which link is active, secondary and tertiary. You could try flex links [http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swflink.html] but they are only good for two links, not three. Another solution could be to use Etherchannel, but that's assuming all three links go to the same switch and all three could be active at the same time.
jackf9333 Tue, 03/18/2008 - 11:13
thanks for the reply the problem is i can only do configuration the root bridge if i was to do metric it would have to be on the other switch, any other ideas?
Collin Clark Tue, 03/18/2008 - 11:36
Trying to get a bigger picture, why can you only change the root bridge?
