SIP trunk between CUBE & Carrier via ASA-NAT
Mar 17th, 2008
CCM5.1.3--CUBE--ASA(NAT)--Carrier
Follows ASA configuraiton and debugging which get fast busy when dial out to Carrier. Please guide me what's wrong in the ASA configuration.
Thanks in advance,
10.0.12.10=CUBE IP@
x.x.x.1=public@ mapped to CUBE
y.y.y.1=Carrier IP@
access-list out_in extended permit tcp any host x.x.x.1 eq sip
access-list out_in extended permit udp any host x.x.x.1
static (inside,outside) x.x.x.1 10.0.12.10 netmask 255.255.255.255
access-group out_in in interface outside
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect pptp
inspect icmp
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect xdmcp
inspect dns
inspect sip
service-policy global_policy global
debug sip
coreasa# SIP::INVITE received from inside:10.0.12.10/53334 to outside:y.y.y.1/5060
SIP::Found From addr "sip:[email protected]" (19)
SIP::Found To addr "sip:[email protected]" (27)
SIP::Found Call-ID [email protected] (46)
SIP::Found CSeq 101 INVITE
SIP::Found expires, 180 seconds
Found port 5060
Found port 5060
Via Port 5060
Found port 5060
SIP::Not updating database for Contact 10.0.12.10/5060, registry database total
Created SIP session for inside:10.0.12.10/53334 to outside:y.y.y.1/5060, 4
total
To: sip:[email protected] (27)
Call-ID: [email protected] (46)
CSeq: 101 INVITE
Found port 5060
Found port 5060
Via Port 5060
Found port 5060
cjrchoi11 Tue, 03/18/2008 - 08:58
It was carrier issue. works okay with 'inspect sip' in ASA.
