Goutam Sanyal Mon, 03/17/2008 - 23:25
  • Silver, 250 points or more
Hi Robert, Is that Cisco IOS/CatIOS or any Operating System? Thanks Goutam.
Jon Marshall Tue, 03/18/2008 - 00:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Robert
IOS
switch(config)# int fa0/5
switch(config-if)# speed 100
switch(config-if)# duplex full
switch# wr mem
CatOS
switch# set port speed 100
switch# set port duplex full
Note that the port will go down and then up when you change the settings.
Jon
rperault94 Tue, 03/18/2008 - 05:44
Thank you. I am not sure whats going on then. Somehow my speed keeps resetting it's self to auto. I will try again, but thats trhe same commands I am using.
Kevin Dorrell Tue, 03/18/2008 - 06:37
  • Green, 3000 points or more
Do you have SNMP management with RW access on the switch by any chance?
Kevin Dorrell
Luxembourg
