Different Flashes
Mar 17th, 2008
Is there a site or can someone explain to me the different types of flashes and are they all model dependent? In other words, on some models of routers/switches, you the image is on the boot flash, some its on just flash, some on the sup..... which is usually found on the 6500s. Whats the difference between them all. Is it really just model dependent or are their reasons for all the different flash? Why do some have both bootflash and just flash, where the image lies in the flash?
aghaznavi Fri, 03/21/2008 - 14:36
  • Silver, 250 points or more
To determine the file system of an external compact Flash memory card, enter the show slot0: all command. To determine the file system of an internal compact Flash memory card, enter the show flash: all command.
