One Way Call
Mar 17th, 2008
Hello
I am having cisco call manager 4.1 and 7902 and 7940 phones. When i configure any phone from that p-hone i can call to other number but from other phone i can't call to this no. When i try to call i am getting the message"Your call cannot be completed Please check the no. you have dialled".i have check the partition aswell as the calling search space everything is ok.and if i restart my Call manager server in that case both way communication is possible.
I want to know that why i am facing this type of problem?Please help.
Thanks.
gogasca Mon, 03/17/2008 - 23:51
  • Green, 3000 points or more
Make sure you are running latest 4.1(3)SR6a
we had an issue in 4.1(3) with no Sr and versions prior to 4.1(3)es119 with CF numbers.
puchkisona Wed, 03/19/2008 - 00:01
First of thanks gogasca.
I have run that pach 4.1(3)SR6a.After that yesterday it woks also.But today the same problem once again.Few new problems also arise.Like i update one phone in ccm it is showing that phone is registered with ccm but i am not able to call this number.and another problem is that When i search the phones by device pool or MAC Address or by phone no.its showing that IP 'Not Found' but i can make the call & also i can receive the call.
So please help.
Thanks.
