ping with datagram size
goutam_04
I am pinging to a outside IP from my network switch, its pinging fine with datagram size 500, but more than 500 datagram its not pinging any IPs. can you tell me what may be the problem/
6 Replies 6
shiva_ial
hi gautam,
if i understand your question correctly. there might be drops of packets
on the path the packet travels
so make sure the path the packets travels
does not have congestion
rgds/shiva
also i have checked in the same network segment, I m pinging to firewall connected direcly to switch, its getting drop more than 500 datagram size. My switch is 3750
your question is very specific
pls specify
where the source you originate the ping ?
destination ?
any intermediate devices in the path ?
how u say 500 datagrams ?
is it size of packet used in ping ?
rgds/shiva
If your are pingen to and public network, DSL, Frame Relay. Check the mtu size of your outside network.
J.
I am not pinging public network i m pinging in same private segment. switch to firewall, which is directly connected.
I am pinging from my network switch to Nokia firewall which is directly connected. there is no imtermediate device. source is my switch and destination is my firewall, I am setting datagram size 500 ( default is 100), yes.
