Asa 5540 CPU Usage
Mar 18th, 2008
Hello, I've got a 5540 that firewalls my production lan enviroment. I monitor the asa with asdm and i am constantly watching that the cpu usage is over 80% even though there are not a lot of active vpn's. Does anyone have some tips on how to make workaround?
allanc_16 Mon, 03/24/2008 - 13:56
From the show process I can see that the process called "telnet/ci" its taking a lot of the resources of the firewall.
From the following link it says that this process is used for:
telnet/ciL: Telnet command interface. One per Telnet session (max 5).
Can you try and completly disable telnet and see if the CPU # goes down?
SpeedLottery Tue, 03/25/2008 - 05:22
Ok, so i entered the cli and removed both of the lines that contain telnet, and realized i dont have access through telnet , i did wr then loaded the asdm did a refresh on the configuration and still the same. 81%
jbadernxo Fri, 04/25/2008 - 23:42
Have u already found the problem?
I am having the same problem on one of my ASA's 5510 on 8.0.2/ASDM 6.0.2. CPU load is on 76% all the time. The processes telnet/ci is causing that.
SpeedLottery Sun, 04/27/2008 - 23:59
Not really, I just reported the problem to my internall tech-support, and what they did was reload (reboot) the firewall.
That will bring the firewall to the normal cpu usage, about 7% or 8%, but i think we still need to do some in depth analysis.
