RE: Addressing Scheme
Mar 18th, 2008
Guys,
Please help!!!
I have been asked to design an addressing scheme that will support 930 users. The design must allow for 30% growth, so if my calculations are correct this would take us to 1209.
Glasgow Office:
50 Warehouse Staff
150 Customer services
100 Finance
Total 300 (still to add 30%)
Birmingham office
75 Warehouse staff
100 Customer services
75 Finance
Total: 250 (still to add 30%)
Five regional sites
Aberdeen 20 staff
Newcastle 40 staff
Liverpool 20
Bristol 20
london 30 staff
Total 250 (still to add 30%
each region also has a number (up to 5) of smaller branch sites with less than 10 staff each.
The company leases a range of class C networks of public IP addresses from its main ISP.
I am trying to find a suitable Network address that will support this.
Many thanks
Scott
Overall Rating: 5 (2 ratings)
Danilo Dy Tue, 03/18/2008 - 04:47
  • Blue, 1500 points or more
Did they give you a range of IP Address to use and subnet?
If not, this means you have a free hand on the ip address assignment. Use some coding in the second and third octet to identify the site and department.
Dandy
scott_mchale Tue, 03/18/2008 - 04:51
Hi Dandy,
No range of IP addresses or subnets given.
Not sure what you mean by "coding in the second and third octet to identify the site and department."
Seem to be hitting a wall everytime when using VLSM.
what Network Address should I use.
Scott
scott_mchale Tue, 03/18/2008 - 04:57
Hi Dandy
Cant see your reply, even though I received an email to advise one had been posted.
Scott
scott_mchale Tue, 03/18/2008 - 05:02
Hi Dandy
Scott
Danilo Dy Tue, 03/18/2008 - 05:13
This means you have a free hand on the ip address range, you don't have to worry about giving the exact requirement. For example, you can give each site/department a /24 (or 255.255.255.0 network mask).
Coding example is the current International Telephone Coding Number which includes country code and area code. For example, if you use 10/8 (or 10.0.0.0/255.0.0.0).
GLASGOW: aaa
- Warehouse Staff: 0 = 10.aaa.0.0/24
- Customer Services: 1 = 10.aaa.1.0/24
- Finance: 2 = 10.aaa.2.0/24
BIRMINGHAM: bbb
- Warehouse Staff: 0 = 10.bbb.0.0/24
- Customer Services: 1 = 10.bbb.1.0/24
- Finance: 2 = 10.bbb.2.0/24
ABERDEEN: ccc/ddd
10.ccc.ddd.0/24
NEWCASTLE: eee/fff
10.eee.fff.0/24
LIVERPOOL: ggg/hhh
10.ggg.hhh.0/24
BRISTOL: jjj/kkk
10.jjj.kkk.0/24
LONDON: mmm/nnn
10.mmm.nnn.0/24
You can replace the letters with either country code or area code. If the code is higher than the valid ip address, make some adjustment. When looking at the routing table, you will be able to easily identify where the route/s came from (and where to route it).
Take note that the above is only an example. It depends if you like the idea and if you really want to follow the requirement,
Dandy
scott_mchale Tue, 03/18/2008 - 05:25
Hi Dandy,
Thanks for your help...
To let you understand I am currently at the end of my Honours year at University, and although the above is helpful, I am afraid I am still a little confused. Is there an easier way to explain this.
Scott
Danilo Dy Tue, 03/18/2008 - 05:27
Well, you didn't mentioned this earlier. It seems that this is one of your project or something for your studies?
I guess you have to follow the requirement. Let me work on something and get back to you :)
scott_mchale Tue, 03/18/2008 - 05:38
If you have the time Dandy, I can certainly send you the document.
Scott
Danilo Dy Tue, 03/18/2008 - 05:49
Try this....
[EDIT] Glasgow Office: 10.1.0.0/22 = 10.1.0.0/24, 10.1.1.0/24, 10.1.2.0/24, and 10.1.3.0/24
- 50 Warehouse Staff (+30% = 65) = The closest subnet is 10.1.0.0/25 (maximum hosts is 126)
- 150 Customer services (+30% = 195) = The closest subnet is 10.1.1.0/24 (maximum hosts is 254)
[EDIT]- 100 Finance (+30% = 130) = The closest subnet is 10.1.2.0/24 (maximum hosts is 254)
Birmingham office: 10.2.0.0/23 = 10.2.0.0/24 and 10.2.1.0/24
- 75 Warehouse staff (+30% = 98) = The closest subnet is 10.2.0.0/25 (maximum hosts is 126)
- 100 Customer services (+30% = 130) = The closest subnet is 10.2.1.0/24 ( maximum hosts is 254)
- 75 Finance (+30% = 98) = The closest subnet is 10.2.0.128/25 (maximum hosts is 126)
Five regional sites
Aberdeen 20 staff (+30% = 26): The closest subnet is 10.3.0.0/27 (maximum hosts is 30)
Newcastle 40 staff (+30% = 52): The closest subnet is 10.3.0.128/26 (maximum hosts is 62)
Liverpool 20 staff (+30% = 26): The closest subnet is 10.3.0.32/27 (maximum hosts is 30)
Bristol 20 staff (+30% = 26): The closest subnet is 10.3.0.64/27 (maximum hosts is 30)
london 30 staff (+30% = 39): The closest subnet is 10.3.0.192/26 (maximum hosts is 62)
Other Senior NetPros may be able to advice a better combination :)
scott_mchale Tue, 03/18/2008 - 05:58
Dandy,
Thanks for your help, greatly appreciated.
Much clearer
Thanks again
Scott
Danilo Dy Tue, 03/18/2008 - 06:17
Please check th update [EDIT], sry I was playing AAO :)
scott_mchale Tue, 03/18/2008 - 06:35
Hi Dandy,
Sorry to bother you again.
Subnetting for Glasgow does not work, it works if we dont allow for 30% growth with the finance department. Or maybe I am doing something wrong. Please advise.
Glasgow Office: 10.1.0.0/23 = 10.1.0.0/24 and 10.1.1.0/24
- 100 Finance (+30% = 130) = The closest subnet is 10.1.0.128/25 (maximum hosts is 126)
Danilo Dy Tue, 03/18/2008 - 06:42
Yes, I noticed that, that's why I update the earlier post. Check the [EDIT] portion. Anyway, here it is
scott_mchale Tue, 03/18/2008 - 07:49
Hi Dandy,
Everything looking good so far, just one other question.....each region also has a number (up to 5) of smaller branch sites with less than 10 staff each. So correct me if iam wrong...5 * 10= 50 for each smaller branch office....so total would be 250 * 30%...
Scott
Hi Scott
Just to add as this is for a Uni Project. The initial posting stated that the company received a range of "Class C" networks so when you are writing this up, change the first octet from "10" to any number betwen 192 and 224 as this is the range of the Class C networks. The 10.x.x.x range are (a) Class A and (b) private Class A addresses (covered by RFC 1918).
Also do not use 192.168.x.x as this is the Class C private range (covered by RFC 1918) and the initial posting stated that the range of Class C networks provided by the ISP were "Public" networks.
Best Regards,
Michael
scott_mchale Wed, 03/19/2008 - 02:17
Michael
Your time and expertise is greatly appreciated.
Many thanks
Scott
Hi Scott
No problem and thank you for the rating.
One correction to my above post, the range of Class C addresses is 192 - 223, not 224 as posted above.
Addresses which start with 224 are Class D addresses and used for Multicast addressing.
Best Regards and god luck with the project,
Michael
scott_mchale Wed, 03/19/2008 - 04:36
Michael,
Probably fed up with my questions, but could I ask, does this look ok!!!
Glasgow 195.168.0.0/22
Subnet Name Needed Size Allocated Size Address Mask Dec Mask Assignable Range
Customer Services 195 254 195.168.0.0 /24 255.255.255.0 195.168.0.1 - 195.168.0.254
Finance 130 254 195.168.1.0 /24 255.255.255.0 195.168.1.1 - 195.168.1.254
Warehouse 65 126 195.168.2.0 /25 255.255.255.128 195.168.2.1 - 195.168.2.126
Birmingham 195.169.0.0/23
Customer Services 130 254 195.169.0.0 /24 255.255.255.0 195.169.0.1 - 195.169.0.254
Finance 98 126 195.169.1.0 /25 255.255.255.128 195.169.1.1 - 195.169.1.126
Warehouse 98 126 195.169.1.128 /25 255.255.255.128 195.169.1.129 - 195.169.1.254
Regional Sites 195.170.0.0/23
Newcastle 52 62 195.170.0.0 /26 255.255.255.192 195.170.0.1 - 195.170.0.62
London 39 62 195.170.0.64 /26 255.255.255.192 195.170.0.65 - 195.170.0.126
Aberdeen 26 30 195.170.0.128 /27 255.255.255.224 195.170.0.129 - 195.170.0.158
Bristol 26 30 195.170.0.160 /27 255.255.255.224 195.170.0.161 - 195.170.0.190
Liverpool 26 30 195.170.0.192 /27 255.255.255.224 195.170.0.193 - 195.170.0.222
Branch Sites 195.171.0.0/22
Small Branch_Aberdeen 65 126 195.171.0.0 /25 255.255.255.128 195.171.0.1 - 195.171.0.126
Small Branch_Bristol 65 126 195.171.0.128 /25 255.255.255.128 195.171.0.129 - 195.171.0.254
Small Branch_Liverpool 65 126 195.171.1.0 /25 255.255.255.128 195.171.1.1 - 195.171.1.126
Small Branch_London 65 126 195.171.1.128 /25 255.255.255.128 195.171.1.129 - 195.171.1.254
Small Branch_Newcastle 65 126 195.171.2.0 /25 255.255.255.128 195.171.2.1 - 195.171.2.126
