ASA5510 - Configuring AAA Servers - Error Message
I created a LDAP server Group. When adding a server in the group, I have configured several different options and after I apply the options and test the connection I always get the same error "Authentication rejected: Memory Error". I do not know where the memory error is. Is it on the ASA device or the authenticating LDAP server?
didyap Mon, 03/24/2008 - 10:20
  • Silver, 250 points or more
Check the following link for a proper ldap config
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008089149d.shtml
If you're still having problems, then run "debug ldap 255" when using the test aaa command. Also, you can do a packet capture on the ASA for traffic between ASA and LDAP server. Also update the ASA software to latest image.
