Media converter AIR-PWRINJ-FIB
Answered Question
Mar 18th, 2008
We have AP 1240AG connected to LAN via media converter AIR-PWRINJ-FIB.
When there is link failure on the fiber side of the AIR-PWRINJ-FIB the cooper port on the media converter is always up and did not detect fiber disconnection effectively AP1240AG did not detect LAN connection failure.
Is this a normal behavior of AIR-PWRINJ-FIB?
Correct Answer by Scott Fella about 8 years 11 months ago
This is normal in install Ihave seen. the issue is the ap does not communicate with the far end switch in spanning-tree. What some have done is put switches on both ends, but that might be costly. You might want to search around for a converter that might have the ability to do this...
This sounds like it can do what you are looking for:
http://www.transition.com/TransitionNetworks/Products2/Family.aspx?Name=E-100BTX-FX-05(xxHT)
Overall Rating: 4 (2 ratings)
Correct Answer
Scott Fella Tue, 03/18/2008 - 07:37
Przemyslaw.Agac... Wed, 03/19/2008 - 01:44
Tank you very much. Have you any written information (documentation) about this functionality leak of AIR-PWRINJ-FIB?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
