paolo bevilacqua Tue, 03/18/2008 - 07:04
  • Hall of Fame,
    Founding Member
Cannot be used for voice.
You can only use cards that have VIC designation (Voice), WIC designation means data (Wan). Some cards can do bot, so are designed VWIC.
Seifeddine-Tlili Tue, 03/18/2008 - 07:36
Damn i know it :( and and i'm going to choose this one VIC2-2BRI-NT/TE Am i right?
paolo bevilacqua Tue, 03/18/2008 - 07:40
  • Hall of Fame,
    Founding Member
Yes. If you need to do both data and voice with BRI you can get both cards and place them in the same router and connect to the same NT.
Only, telco will have to provision the circuit as multipoint (no static tei). This way both cards will be be able to use it, even simultaneously.
As an appreciation to those providing useful answers, please rate post with the scrollbox below!
