CTIOS Agent Desktop
Mar 18th, 2008
Hello We are using version 6.0.0 of the CTIOS Agent but have hit a problem in that we are using Windows XP SP2 , so everytime you try and dial via the agent it crashes (known problem), BUT what replaces 6.0.0 that works with XP Sp2 ??.
We have tried a version 7.x client but that does not work saying that ther is a missing dll.
Can anybody help ?
Scott.
venchalam Wed, 03/19/2008 - 00:41
Try to install .Net frame work 2.0. Since from 7.x all libraries are from .Net.
Riccardo Bua Wed, 03/19/2008 - 04:34
  • Cisco Employee,
Hi Scott,
Problem is fixed with CTIOS 6.0 SR4, you just need to download the patch.
Riccardo
sdawson35 Wed, 03/19/2008 - 05:28
Our client is 6.0.0, there does not appear to be any patch or release for this !!.
The only patches on the website ate for 6.0(1)_SR4 or 6.0(2)_SR4 when I try to install either of these patches I get an error message saying that these patches are not needed.
Riccardo Bua Wed, 03/19/2008 - 06:07
  • Cisco Employee,
Riccardo Bua Wed, 03/19/2008 - 06:10
  • Cisco Employee,
Forgot to mention as per the Release Note you need first to install the patch on your server.
Riccardo
