CSM 3.1.1 cannot discovery 7301
Mar 18th, 2008
We have Cisco Security Manager 3.1.1. I succesfull added ASA5540, FWSM, 6500 and 2811. But I cannot discovery 7301. Test connection is OK, device add but in discovery process is failed (sleep one minutes on 24% and say Discovery Failed).
We have four 7301 routers for VPN Site-to-Site.
Device is reacheble from CSM Server (check by SSH).
kwillacey Wed, 03/19/2008 - 06:25
What is the message you get when it fails? This can help you to pinpoint the problem.
dkuzmenkov Fri, 03/21/2008 - 00:44
Im resolved this problem. My router has disable https server, but the discovery process use https for IPS systems in router.
Im disable IPS discovery and its work fine!
