Unity Express + RightFax 9.3
Mar 18th, 2008
Within the compatibility matrix of CUE there is not mention about third-party applications such RightFax 9.3. Can somebody help me to verify if they are compatibles?
I appreciate any help on this!
Ginger Dillon Tue, 03/18/2008 - 11:16
Hi -
Can you tell us what type of compatibility or functionality you are looking for with CUE & RightFax? For example, Unity unified messaging has Third Party Fax administration which allows enabled subscribers to have recognition of the fax message class(s) in the inbox when checking new messages. The fax subject line is presented to the subscriber and the fax can be routed to a hardcopy fax machine. Is that the type of thing you are looking for?
mmasis Tue, 03/18/2008 - 11:21
That was exactly what i was looking for but i already found it in the captaris documentation. I really appreciate your response.
