WPA-PSK keys
Bare with me, I'm new to wireless.
I'm trying to change the WPA keys and I can't get it to take. This is the present settings:
aaa session-id common
dot11 ssid !abbessidprivate!
vlan 1
authentication open
authentication key-management wpa
infrastructure-ssid optional
wpa-psk hex 7 BCBA028E263B5C5789D29D55E3F03E7E2CF0B2A9915B19FD626036D79092F06
07D
What commands do I need to enter wpa-psk hex 7? These have already been setup, but the guy put in the wrong key. I need to know how to change it.
DJ
What commands do I need to enter? I tryed this:
41-AccessPoint-1(config-ssid)#wpa-psk hex 7
% Ambiguous command: "wpa-psk hex 7"
41-AccessPoint-1(config-ssid)#wpa-psk hex 7?
7 WORD
41-AccessPoint-1(config-ssid)#wpa-psk hex 7 ?
Hex-data 66 hexadecimal digits
41-AccessPoint-1(config-ssid)#$D69769D94C396017BE9646D05C593A3366C0F
Invalid key length, expecting 66 hexadecimal digits
41-AccessPoint-1(config-ssid)#$341CACECD69769D94C396017BE9646D05C593A3366C0F
41-AccessPoint-1(config-ssid)#!
41-AccessPoint-1(config-ssid)#end
41-AccessPoint-1#show runn
It didn't change....
izackvail Tue, 03/18/2008 - 14:52
Is there a reason why you are entering the key in hex? If you can I would recommend entering the key in ascii. eg. "wpa-psk ascii thisisthekey1234". If you must enter the key in hex try "wpa-psk hex 0 hexkey". If that doesn't work try "wpa-psk hex hexkey".
zubaircco Mon, 05/26/2008 - 02:26
Hi DJ,
Have you tried accessing the AP via your web browser? I setup a AP 1200 using the GUI and it was slightly easier?
Rgds,
Z
