DMP to SVGA Monitor
Mar 18th, 2008
Does anyone have suggestions on how I can use an XVGA/SVGA monitor connected to a DMP? Would like to avoid purchasing a new Monitor and be able to reuse one of my spare monitors to display or test5 the output of a DMP.
Brandon Buffin Thu, 03/20/2008 - 12:40
One option is to buy a converter to convert from S-video to VGA. Do a Google search for "s-video vga converter". You'll find several options.
Hope this helps. If so, please rate the post.
Charles Little Tue, 04/15/2008 - 01:26
If the monitors have DVI inputs you can get a cheap adapter to get from HDMI to DVI. You may be able to get a S-video to SVGA adapter. Not sure if I have seen that one though.
