Mix CFC and DFC in same chassis
Mar 18th, 2008
I have read some information regarding the mixing of CFC and DFC in the same chassis (6513 chassis) Will there be any running of the lowest common denominator for these two different types of cards?
CFC's on the top portion and DFC in the lower portion of the chassis.
Joseph W. Doherty Tue, 03/18/2008 - 11:47
I don't recall limitations of card placement solely dependent on CFC or DFC within the 6513 chassis. What you might run into is the issue that dual 20 Gbps channel fabric connections are not provided to all line card slots within the 6513 chassis.
