Paolo Bevilacqua Tue, 03/18/2008 - 09:02
  • Hall of Fame,
    Founding Member
All cisco routers/voice gateway do support h.323.
The CM doesn't care which exact device it is, as long configuration is reasonably correct.
Paolo Bevilacqua Tue, 03/18/2008 - 09:45
  • Hall of Fame,
    Founding Member
Actually I believe that even a non cisco device that complies with H.323 would work as GW with CM.
ricardorojas123 Tue, 03/18/2008 - 10:05
p.bevilacqua,
I can use a 3545 PRI Gateway ? To route the call of the call manager?
Paolo Bevilacqua Tue, 03/18/2008 - 10:36
  • Hall of Fame,
    Founding Member
Hi, this is a question you've asked in another thread, someone has provided an answer, honestly I don't know the answer.
Jaime Valencia Tue, 03/18/2008 - 14:20
  • Cisco Employee,
  • Hall of Fame,
    2011
i've already replied to your other thread on that and provided a link with the supported gateway models
Have you been able to look at the information?
javalenc
Paolo Bevilacqua Wed, 03/19/2008 - 12:05
  • Hall of Fame,
    Founding Member
If you enter your username in the search box on the right side, you will see all the threads you've posted to, and the answers provided.
