Callmanager CDR reporting
Answered Question
Mar 18th, 2008
is there a way to pull total number of calls for each pri? on cdr reporting
Correct Answer by pklos about 8 years 10 months ago
Yes, in CDR database. For outgoing calls check field DestDeviceName (you'll have there gateway name, for h323 just IP, but for MGCP there is full PRI name - so you can check interface) and for incoming you can check OrigDeviceName.
regards,
PK
Overall Rating: 5 (1 ratings)
Correct Answer
pklos Tue, 03/18/2008 - 09:28
regards,
PK
