How does RME 3.5 support configuration baselining?
Answered Question
Mar 18th, 2008
I am slightly at a loss as to the exact support for config baselining in SNMS 1.5 + RME 3.5.
- Is it possible to define a template and compare active device configurations to that template?
- Is it possible to generate a template based on a current device configuration and compare that to every other device in the network?
- Is it possible to apply such a template to a new device and configure local options (interface, access lists) from there?
Note: I am using SNMS 1.5 and not LMS!
Thanks for the help!
Correct Answer by Joe Clarke about 8 years 7 months ago
You can do baseline template comparisons in RME 3.5 using the cwconfig CLI command. See for more details on using this feature. If you want to deploy changes based on a baseline, this requires RME 4.0.
Overall Rating: 5 (1 ratings)
