OID
anitachoi3
I would like to update the MRTG to monitor the call-rate. the cisco command is "show isdn call-rate". does it have OID for it?
rdgs
David Stanford
There is no single MIB object that will give you this output. Have a look at the ISDN-MIB and you can see which objects you might want to query.
I would like to config the spike control on as5400 with 16 T1 circuits. what is the suggestion value?
conf t
call spike <0 - 2147483647>
It is around 10 T1 full when peak hour.
rdgs
