How do I remove an ACL in ASA 7.0(7)
Answered Question
Mar 18th, 2008
It seems to work on all my other Cisco devices but here on my ASA 5510 when I type:
No access-list 102
It doesn't work.. it just say incomplete command. It wants a Deny, Permit, Line (etc) statement. I have two ACL's I want to delete.
Any Clue?
Correct Answer by michelcaissie about 9 years 2 months ago
you now need the " clear configure access-list " command in config mode to remove an entire acl.
Overall Rating: 5 (2 ratings)
Correct Answer
michelcaissie Tue, 03/18/2008 - 12:27
shawnreis Tue, 03/18/2008 - 12:33
After spending the better part of 2 hours trying to find the command you have saved me in 10 Min.
The Command worked great.
Thank you.
Shawn
jjohnston1127 Tue, 03/18/2008 - 14:15
  • Silver, 250 points or more
Try:
clear config access-list 102
That will wipe out any configuration details related to access-list 102.
[edit] Wow - I feel dumb. i didn't see the replies.
shawnreis Fri, 03/21/2008 - 10:11
You shouldn't feel dumb.. you knew the answer.. That's better the me.
