bpduguard enable on Catalyst 3548XL
Mar 18th, 2008
I have a Catalyst 3500 XL running IOS version 12.0(5)WC17 and I wanted to enable bpduguard on the interfaces, however, I found that the command "spanning-tree bpduguard enable" is not supported on this switch. I can not find a higher version of IOS for the 3500XL platform on the Cisco web site so my question is what are my options if I want to enable pbduguard on the interfaces of this switch, am I just out of luck?
glen.grant Mon, 03/24/2008 - 14:47
I would check the implementation commands as these switches are ancient and the IOS commands on the old 3500xl are not always same the as current IOS commands .
