03-18-2008 12:53 PM - edited 03-13-2019 05:05 PM
Hi All,
I am quite new here. We have just deployed in beta our new Cisco VoIP phone system. We have numerous GN Netcom 2110 and 2115 headsets. The Jabra website states these are compatible with 7900 series Cisco IP Phones.
However, when we connect them into the headset port, we do not hear anything through them. The only settings I can find are on the Device configuration:
Wideband Headset UI Control
Wideband Headset
Both are enabled and I have toggled both together and individually on and off.
Is there another setting/config somewhere that is preventing the headset from working?
Any help would be great! Thanks!
*NOTE: My apologies, this should have been posted in IP Telephony
03-18-2008 03:51 PM
Hi Dan,
These GN Netcom models will work but likely have the wrong Quick Disconnect cords for the Cisco 7900 series pin-out. You will need one of these;
GN Netcom 8800-02 Direct Connect Cord for Cisco
(Model # 27361101)
Cord allows you to plug-in the GN 2100 series headsets directly into Avaya, AT&T, Lucent, Callmaster V, Callmaster VI and 500 AM Cisco 7900 Series telephones. Also used to connect GN Netcom headsets with Plantronics M10 or M12 amplifiers.
http://www.twacomm.com/catalog/model_27361101.htm?sid=C6795F1D73EEF15D2C45EA09FDAE4CEA
Or this âSmart Cordâ
From this doc;
http://telecom.hellodirect.com/eBiz/pdf/headsetaccessories/GN_Netcom_1200_Smart_Cord_Spec_Sheet.pdf
Hope this helps!
Rob
03-19-2008 08:23 AM
Alternatively, if you phone has no "PC headset connectors" (on the left bottom side of the phone), you may get a PC headset adapter, which plugs into the RJ-9 headset jack (on the back of the phone), and use a computer multimedia headset.
Michael
04-15-2008 07:30 AM
You need IPhone of the new generation like Integrated control of wireless headsets is a key feature which
differentiates the Cisco 'Advanced Media' Unified IP Phones
(7942G, 7945G, 7962G, 7965G and 7975) in the marketplace
HHC requires Cisco Unified Communications Manager 4.1(3) or above plus the 8.3(3) phone firmware version. Available in November 07.
For more information on which deskphones support HHC refer to www.jabra.com/cisco
just I have one problem with this combination CCM 4.1(3)SR5 plus IPhone 7945 (SCCP 45.8-3-4SR1S) plus GN9350 plus HHC I can't change the settings-->Device Configuration-->Media Configuration-->Headset Hookswitch Control to Enable if you known how do this please let me known..
04-15-2008 09:26 AM
Hi Antonio,
From CCM Admin search Device>Phone> to find the 7945 in question. Once you find the Device look down at the bottom of the page (you will see);
Wireless Headset Hookswitch Control (Enabled/Disabled)
Hope this helps!
Rob
04-15-2008 10:28 AM
04-15-2008 11:21 AM
Hi Antonio,
It is available on our 4.2(3)sr3 :( I'll do some more research later when I get back to the office.
Rob
04-16-2008 05:08 AM
Hi Antonio,
I cannot seem to find what version of 4.1(3) adds this support :( I have gone through the 4.1(3)sr6a release notes but do not see any reference for the Wireless Headset Hookswitch Control.
I have opened a support case with Jabra so I'll let you know when they get back to me.
Hope this helps!
Rob
04-16-2008 07:35 AM
Hi Rob
I try with a upper version of de CCM 4.1(3) available on cisco before I start think on move to other version like CCM 4.2(3) or any other.
Rob if you have any kaind of responsed by Jabra pleas let me known all advices are good and take it consideration.
Sorry everybody by my poor english
