03-18-2008 01:57 PM - edited 03-13-2019 05:05 PM
Is it possible to route incoming fxo call on cme via the caller id? I would like options for anonymous callers. I do not have aim-cue.
Solved! Go to Solution.
03-18-2008 03:03 PM
Problem is that often there are legitimate calls, eg long distance or international, that have no clid.
Anyway if you want to reject calls with empty clid:
voice translation-rule 100
rule 1 reject /^$/
voice translation-profile no-anon
translate calling 100
voice-port x/y
trunk-group fxo
trunk group fxo
translation-profile incoming no-anon
03-18-2008 03:03 PM
rule 1 reject /^$/
voice-port x/y
trunk-group fxo
trunk group fxo
03-19-2008 01:33 PM
Dear Sir;
You are the man!I have looked high and low for this answer.Could you direct me to a place on this site where I could learn more? Excellent response.
03-20-2008 08:08 AM
thank you very much for the appreciation.
The cisco references and guides are very good, but to go beyond that I suggest the cisco press books and practicing a lot.
