static nat by destination outside to inside
Mar 18th, 2008
HI.I'm using Static nat with route-map to translate my server x.x.x.x to y.y.y.y or z.z.z.z depending on the incoming (outside to inside) traffic.
ip nat inside source x.x.x.x y.y.y.y route-map from1-to-y
ip nat inside source x.x.x.x z.z.z.z route-map from2-to-z.
But every incoming traffic to y or z is translating to x whatever the source may be !!!!
even not in acl of the route-map !!!
route map seems to be only there to allow more than one static translation of one source address .
(for outgoing traffic, the route-map works properly)
Can i get some help please.
